04-26-2016 06:15 PM
Hello all,
I am trying to control two (or more) solenoid valves continuously and simultaneously using a NI 9485 which has 8 SSR channels. I tried using two different VI's which apparently does not work because I am using the same hardware (although different channels). Using two DAQ assistants (in two separate loops) caused the same problem. Seems like my only chance is to control them using a single DAQ assistant. The problem with this method (appart from the inconvenience of using only one DAQ assistant) is that I get an error for a mismatch between the array dimensions between DATA and TASK. I tried assigning a 2D boolean array to the DATA but it did not work. I would appreciate it if someone can help me with some specific details as I am new to the LV.
04-27-2016 05:26 PM - last edited on 01-08-2024 02:15 PM by migration-bot
Hi SiaVahidi,
In the link below there is a tutorial for getting started with the DAQ Assistant. In the first lesson, NI-DAQmx Express VI Tutorial, there are many good examples for what you can do with this Express VI and best practices for using it. I hope this helps!
Using the DAQ Assistant: https://www.ni.com/en/support/documentation/supplemental/06/getting-started-with-ni-daqmx--main-page...
Best Regards,
William
