03-27-2015 04:06 AM
I'm designing an application that sequencely turn on 6 LEDs, each LED operaters in periodes of 10ms, and then is off the rest of the time. To control the intensity of the LED in the 10ms periode I want to use a PWM signal.
Any suggestions?
04-02-2015 03:16 AM
Dear kjschmidt,
It is not a 100% clear to me what you mean by your post.
What is the Duty cycly of the PWMs you want to create?
What is your switching frequency? (10 ms?)
Please share the following informatoon:
- the code you currently have written.
- the hardware you are using to do sent out the digital signals.
- A description of your HW set-up and how everything is connected with eachother (DAQ device, LEDs, wires, ...)
04-07-2015 01:34 AM
I found this example, which solves my issue with controlling the intensity of the LED with PWM signal.
The example also contains a timer, but I don't how to use it correctly. To satify my needs, the timer should shiftly turn one LED on in 10ms when the others are off.
Hopes this makes sense
Also I'm using a USB-6351 DAQ with 4 LEDs connected to Digital OI port 0:3
04-07-2015 01:53 AM
Hello kjschmidt,
Do you fully understand what the example code does?
Or in other words:
Do you understand what each of the steps in the example code does and why it is necessary?
If I understand correctly, then you want to have something that:
Is this what you mean?
The reason why I am asking is because your 2 posts contradict eachother (4 LEDs vs 6 LEDs).
Have you followed any DAQmx Data Acquisition related training?
04-07-2015 01:53 AM
Hello kjschmidt,
Or in other words:
04-07-2015 02:02 AM - edited 04-07-2015 02:06 AM
Yes I understand each step, except the counter/timer part.
And sorry for the misunderstand about the numbers of LEDs. The final code should be able to control 6 LEDs, but currently I'm am testing on 4 LEDs.
Regarding your bulletpoints that is exactly what I'm looking for.
And no, I haven't followed any DAQmx related training.
I've attached what I made so far. As you can see I'm controlling which LEDs that is one with a indicator, and this is where I need help.
Thanks in advance.
04-07-2015 07:40 AM
Hello kjschmidt,
I have made a simple example to illustrate what happens.
Please let me know if everything is understood from this example.
I have tried to document verything that seemed to require an explanation.
Any attached Code is provided As Is. It has not been tested or validated as a product, for use in a deployed application or system, or for use in hazardous environments. You assume all risks for use of the Code and use of the Code is subject to the Sample Code License Terms which can be found at: http://ni.com/samplecodelicense
04-08-2015 12:54 AM
Thanks you very much!
I wasn't familiar with the Append Digital Samples - that is usefull
04-08-2015 01:28 AM
No problems!
