Digital I/O
Connect Mercury 3500 to NI 9401
Hi
I am trying to connect Mercury 3500 encoder to NI 9401. The pin configurations are confusing and any help is appreciated.  The follwoing is what I think should work, but I am not sure.
Encoder PIN    NI 9401 PIN
4                       1
5                      14
9                      16
10                      3
14                     17
15                      4
(4,757 Views)
Accepted by ExcelX
Hi ExcelX,
Currently, you are wiring the two instruments together as it is shown in the attached connection_diagram.png
I am not too familiar with Mercury 3500 but think you need to wire pin 9 (Mercury 3500) to pin 3(NI 9401) and pin 10 (Mercury 3500) to pin 16 (NI 9401) to make sure all your negative terminals are wired to the COM terminal on 9401. Also you need make sure both instruments share a common ground, so you will also need to wire pin 1 or pin 13 on Mercury 3500 to NI 9401 ground.
Mikhail
RF Toolkits, Product Support Engineer
(4,746 Views)
