03-14-2013 05:02 AM
03-15-2013 04:14 AM
Hello tekla,
is this a question? if so can you be more specific about the hardware you use and on those multible triggers you intend to use.
Two lines of text leave much space for assumptions ...
Best Regards!
Moritz Mayer
03-19-2013 05:34 AM
Hi tekla,
here you can find a lot of information about Data Acquisition with DAQ-devices:
http://www.ni.com/white-paper/5434/de
http://www.ni.com/white-paper/4329/en
You can also search for DAQ examples in LabVIEW for your specific device. Go to "Help" --> "Find Examples" in LabVIEW and choose your hardware on the bottom of the NI Example Finder window and enable "Limit results to hardware".
Hope this helps
Suse
