02-27-2015 11:44 AM
The outputs on the NI PXI-6515 are an open collector with a Darlington pair transistor. In my application the emitter is tied to ground and a 10k resistor is tied between the collector and +5VDC. A measurement is taken at the collector to determine Hi or Low (TTL values).
NI does not publish the collector emitter voltage on their darlington transistor outputs on the NI 6515 when it is fully saturated. What is the full saturation current and what is the full saturation collector emitter voltage?
Mike
03-02-2015 10:44 AM
Hi mdricken,
Thanks for posting to the forums. I think this document has the specs you're looking for:
http://digital.ni.com/public.nsf/allkb/8D46388A20C5A23E862572B8007E8C82
