06-25-2013 11:54 AM
I'm very new to Labview and so I was hoping that I might be able to get some help here. I've inherited a project and a lot of labview code, and as I piece through it I'm updating it, cleaning it up, and trying to modify it for new testing new products that we are releasing soon. I have a piece of code here that basically uses an NI PCI-6251 counter card to read in some digital waveforms. I'm trying to convert that code to work with the NI PCI-6602 counter card that we also have.
I basically pulled out the code that is at the base of our VI's that I need most and that has been causing me the biggest headaches. I have three I/O controls, NI6251/Ctr0, NI6251/Port0, NI6251/PFI12 and they work fine. When I switch them to NI6602/Ctr0, NI6602/Port0, NI6602/PFI12, then I get some errors having to do with the counter cards ability to sample.
Here is the error that I am getting:
Error - 200077 occurred at Property Node DAQmx Timing (arg 1) in DAQmx Timing (Sample Clock).vi:2->getwaveforms.vi
Possible reason(s):
Requested value is not a supported value for this property.
The property value may be invalid because it conflicts with another property.
Property: SampTimingType
Requested Value: Sample Clock
You Can Select: On Demand
Task Name: _unnamedTask<A2A4A>
When I try to select On Demand however from that dropdown menu, it is not listed. Any suggestions on what I need to do?
Thanks!
~Jason
06-26-2013 08:39 AM
06-26-2013 09:41 AM
Hi Jason,
The behavior you are seeing is expected. The reason error -200077 is occurring, telling you cannot select Sample Clock on the your DAQmx Timing VI, is due to the fact that your PCI-6602 is not capable of performing hardware timing. You did not see this error with your PCI-6251 because it has hardware timing capabilities.
Beause of this, you will have to have your application run with software timing. The reason the DAQmx Timing VI does not have the option for "on-demand" timing is because on-demand timing is the default setting with no DAQmx Timing VI. That specific VI is inteded to be used to configure hardware timing. Thus, if you remove the VI altogether, your applicaiton will run using software timing.
Hopefully this helps.
06-26-2013 10:57 AM
Thank you both for your responses.
If I need to be able to sample at higher rates that software timing can allow for, am I able to use an external clock fed into the NI6602 board for triggering?
06-26-2013 11:03 AM
06-26-2013 01:21 PM
So I've switched to doing it with software timing, and I was able to get this before, but what I'm having trouble doing now it getting my waveform to concatenate data as it comes in. It is centering the data around zero, and instead of scrolling, or appending new data on, it simply overwrites. And I need to see the whole waveform, not just the bits flipping in place.
I've attached the VI
