03-28-2013 01:45 PM
Hello dear partners,
I'm using NI DAQmx 9.7 in a machine hosting a Windows 7, but always when I tried to run the application I got this error.:
CAN'T LOCATE THE DRIVER ERROR 10240
I can see that it happens when I tried to call this function.: DIG_Out_Line(short device,
short port,
short line,
short lineState) from dataacq.h file
Previously I was using the driver NI DAQ 7.4.4 (Legacy) in a machine hosting a Windows XP, but I believe it doesn't work very well on Windows 7 even running in compability mode.
Does you have any idea why could I'm facing this problem ?
Best Regards
Josias Junior
11-25-2013 09:16 PM
Hi!
I Have the same problem!
- NI-DAQmx 9.7.5
- Windows 7 Home Basic
and the DIG_Out_Line reply an ERROR:
11-26-2013 10:59 AM
11-26-2013 11:12 AM
I'm using an Application compiled in LabWindowsCVI 2009
I Find this topic: http://digital.ni.com/public.nsf/allkb/8EC9E81C3DE4E619862573930083BD7A
"Traditional NI-DAQ (Legacy) 7.5 Beta"
I will try to intall it and see how it works, i will keap in touch on the progress...
Best Regards..
11-27-2013 06:10 AM
Is not necessary make this. Your Windowns and your PCI are compatible with NI-DAQmx 9.7 but, maybe you installed you LabWindowns on default module and forgot of install something.
1º Step - Run a EXAMPLE and see that everything will work or if the same problem is display for you.
2ª Step - With the same problem appear send me your MAX Report.
- Open MAX
- Click on "File"
- "Create a Report"
- Send to the file to Technical Support
Regards
11-27-2013 06:14 AM
