09-30-2013 02:04 PM
I use the board name PCI-DIO_96. The board has 11 ports. Because of some reason, i have to trigger several DOs at the same time, but these DOs are at different ports.
For example, the 1st line is @ port0/line1, the 2nd line is @ port4/line3 ......
But after test, i found the C# program cannot trigger all the DOs...???
I wonder if it's better to trigger the DOs at the same port than trigger DOs at different port at the same time?
Thanks!
Kevin
10-01-2013 02:24 AM
No different.
10-01-2013 01:33 PM - last edited on 02-15-2024 10:37 AM by migration-bot
Hello Kevin,
PCI DIO 96 boards timing is software based. Meaning you will get a difference of 1 to a couple of ms between triggers. This is because is OS/SW dependant. It would not matter if you do it on same port or different ports. If you are interested in précised triggering, you might need to look into using hardware time boards.
https://www.ni.com/en-us/shop/model/pcie-6535b.html
Good luck with you project.
