Digital I/O
Can Sample Timing Type be changed from within MAX?
Hello All,
  Trying to setup a few simple digital IO tasks using the DAQ Assistant within MAX.  My particular IO device does not support an internal sample clock, so I need to change the "Sample Timing Type".  I've seen how to do it from within Labview, and within Signal Express, but can't find where to change it in MAX.  Please advise.
Thanks much.
GSinMN
(5,222 Views)
Accepted by topic author GSinMN
If your device does not support hardware timing, you cannot change it in MAX, SignalExpress, or LabVIEW. If you actually attempted it in SignalExpress or LabVIEW, you would get an error.
(5,219 Views)
