Digital I/O
Can I use the C interface routines of a USB-6501 with a Raspberry Pi?
I have a USB-6501 that I have used with my own C code in Windows. I would like to port that code to run on a (Raspbian) Raspberry Pi, but I can't seem to find any driver sets that will work. I found a demo program from a few years ago that can run on a Pi, but nothing I can use with my own code.
Are there any drivers? Or is there a way to get the driver library compiled for a Pi? I have another (non-NI) piece of USB hardware for which I was able to recompile the driver library on the Pi, and it is working fine.
(4,447 Views)
Hi jkruep,
I don't know if this device is supported for sure, based off of this forum post:
USB protocol of the USB-6001
But here are some links that might help get you started with more research to see if that post is out of date or wrong:
Low Cost USB DAQ Driver for use with Raspberry Pi®
Getting Your RPi Ready For C Programming
NI-DAQmx Base 3.x C Function Reference Help.pdf
I hope this gives you a good starting point.
G-IV
(4,428 Views)
Thanks for the reply, G-IV.
I hadn't found that first link before (USB protocol of the USB-6001). It eventually led to a hardware driver development set, which I looked at for a little while. I'm not sure I really want to go that far into it, though.
I had seen the second link previously0.(Low Cost USB DAQ Driver for use with Raspberry Pi®) I installed it, and it works as it it supposed to. But it seems like just a couple demo programs, and doesn't include the source routines or compiled raspberry pi libraries I would need for my system.
I guess I may just have to abandon my USB-6501 for this purpose.
Thanks again.
(4,399 Views)
