02-10-2013 01:35 PM
Can I use (and how do I do it)a NI 6009 DAQ Device as a swith to close a ciruit?
02-11-2013 07:34 AM
You can't use the 6009 as a switch. You can use the DIO to control a switch (like a FET or transitor). How you would do this really depends on your application.
02-11-2013 09:33 AM
The only thing that the 6009 can do is apply a voltage. If switching between different voltages is what you need, then sure.
