Digital I/O
Can I use a NI 6009 DAQ device to act as a switch to close a circuit?
Can I use (and how do I do it)a NI 6009 DAQ Device as a swith to close a ciruit?
(6,090 Views)
You can't use the 6009 as a switch. You can use the DIO to control a switch (like a FET or transitor).  How you would do this really depends on your application.
GCentral
(6,075 Views)
The only thing that the 6009 can do is apply a voltage. If switching between different voltages is what you need, then sure.
(6,068 Views)
