07-08-2014 07:26 AM
I'm using CRIO to acquire digital inputs, and each one requires a frequency of 1kHz, in this case I'm Afraid to exceed CRIO's acquisition Capacity knowing that CRIO requires a frequency less than 500Hz
In your Opinions, It is dangerous what I'm trying to do ?
Thank you in advance for your advices
My Kind regards
Solved! Go to Solution.
07-08-2014 08:00 AM
What digital module are you using? Are you using the FPGA? What cRIO are you using?
07-08-2014 08:48 AM
I'm using module NI 9403 (Scan Interface)
07-08-2014 09:09 AM
Yeah, the scan interface can't go that fast. But that module will work at up to 140kHz. You will want to change to the FPGA interface in order to do this properly.
