I'm trying to read buffered data from a NI USB-6210.
My goal is to sample the linear position(edge count) and the time the edge occurred.
For the time I use the internal sample clock.
But I don't get it to work. What am I doing wrong?
Thanks for your help!
My code for now:
namespace LinearPositioningBuffered
public partial class MainWindow : Window
private Task aiTask;
private Task counterTask;
private Task runningTask;
private CounterReader counterInReader;
private AnalogMultiChannelReader reader;
private AsyncCallback asyncCB;
private double[] data;
private int BufferSize;
public MainWindow()
InitializeComponent();
uxStopButton.IsEnabled = false;
asyncCB = new AsyncCallback(CounterInCallback);
private void ReadChannelBuffered()
int sampleRate = 1000;
BufferSize = sampleRate * 10;
bool zIndexEnable = false;
double zIndexValue = 0;
double intialPosition = 0;
double distPerPulse = 1;
try
aiTask = new Task();
// create a channel
aiTask.AIChannels.CreateVoltageChannel("dev2/ai0", "", (AITerminalConfiguration)(-1), -5, 5, AIVoltageUnits.Volts);
// Configure timing specs
aiTask.Timing.ConfigureSampleClock("", sampleRate, SampleClockActiveEdge.Rising, SampleQuantityMode.ContinuousSamples, 2000);
// Verify the task
aiTask.Control(TaskAction.Verify);
counterTask = new Task();
counterTask.CIChannels.CreateLinearEncoderChannel("dev2/ctr1", "LinearPosition", CIEncoderDecodingType.X1,
zIndexEnable, zIndexValue, CIEncoderZIndexPhase.AHighBLow, distPerPulse, intialPosition, CILinearEncoderUnits.Meters);
//Configure timing
counterTask.Timing.ConfigureSampleClock("/dev2/ai/SampleClock", 0, SampleClockActiveEdge.Rising, SampleQuantityMode.ContinuousSamples, BufferSize);
counterTask.Control(TaskAction.Verify);
runningTask = counterTask;
counterInReader = new CounterReader(counterTask.Stream);
counterInReader.SynchronizeCallbacks = true;
counterInReader.BeginReadMultiSampleDouble(BufferSize, asyncCB, counterTask);
// Read the data
reader = new AnalogMultiChannelReader(aiTask.Stream);
reader.ReadSingleSample();
uxStartButton.IsEnabled = false;
uxStopButton.IsEnabled = true;
catch (DaqException exception)
counterTask.Dispose();
runningTask = null;
MessageBox.Show(exception.Message, "ReadChannelBuffered");
private void CounterInCallback(IAsyncResult ar)
try
if (runningTask == ar.AsyncState)
data = counterInReader.EndReadMultiSampleDouble(ar);
for (int idx = 0; idx < data.Length; idx++)
Console.WriteLine(string.Format("{0}: {1}", idx, data[idx]));
MessageBox.Show(exception.Message, "CounterInCallback");
Stop();
private void Stop()
runningTask = null;
uxStartButton.IsEnabled = true;
private void uxStartButton_Click(object sender, RoutedEventArgs e)
ReadChannelBuffered();
private void uxStopButton_Click(object sender, RoutedEventArgs e)
Stop();
