06-28-2016 11:17 PM
HI
I have 2 questions.
1) Can I use data port as clock signal? If yest, How do I assign/export a 60MHz generated clock to the lvds clock out signal on NI 6587 adaptor module.
Similarly if we are using an external clock as input, is it necessary to assign **bleep** to dedicated strobe out signal? Can't data port be used as clock signal within the labview software?
2) Can we change clock edges? I am currently working on the positive edge of the clock. When I switch SMAs from p to n and n to p, the software does not run. how do u change clock edge in labview when using NI 7962R FPGA module and NI 6587 adaptor module?
thanks
06-30-2016 09:32 AM
Hi incisive,
I believe the following article will answer your first question: http://digital.ni.com/public.nsf/allkb/7958A6FA2ABDB84A862575910079B926.
I'm going to have to look further into changing the clock edge in LabVIEW before I can give you a clear answer on your second question.
06-30-2016 09:59 AM
07-01-2016 01:00 PM
I guess I'm still a little confused on what you are trying to do. Could you tell me exactly what signals you want to export and where you want them to go (a diagram might help)?
Thanks!
