09-06-2016 08:46 AM
Is a 9401 module capable of driving a small (5amp) SSR with a 4-15 volt input?
Solved! Go to Solution.
09-07-2016 11:52 AM
Technically yes, since the NI 9401 can ouput 5 V, but that is not what it is meant to be used for. You're better off buying a cheap power supply (like 10 dollars) then just making a circuit that controls that power supply with the NI 9401.
What is your application and why are you looking into the NI 9401? NI offers help with specing out systems.
1 (800) 531-5066
-Bear
09-07-2016 03:25 PM
Well, basically I'm trying to repurpose an existing test rig and I've no choice but to use the hardware on hand. It was to be used to turn a motor on and off. I think I've answered my own question because I found the input on the relay draws 15ma and I don't think the 9401 will output that. I wanted to do it cheap 'n dirty but now I'm thinking I'll have to use a BLDC motor and using the 9401 to generate a PWM signal to the controller. A tad more complicated but doable.
Thanks for the input
09-07-2016 08:16 PM
You should consider using a buffer chip that can output the current you need, like this one. This will require a 5V power supply, but it does the job.
09-08-2016 07:40 AM
Acually the more I thought about it the more advantages I could see to switching to a BLDC motor mostly being able to control the speed. I'll have to see what happens. If it doesn't work out I'll definetly look into the buffer chip.
