Digital I/O
8452 streaming API change chip select
I am able to stream a command successfully using the streaming API.  However, it the default is CS=0.  How do you change and use the other chip selects?   I want to be able to select CS0 to CS7.
Bob
(3,310 Views)
Hello Bob,
Can you post a screenshot of your code, specifically where CS0 is being set and which function/VI you're referring to?
(3,289 Views)
Here is the labview code.  There is no where to change the chip select.  It defaults to CS0.
(3,207 Views)
