09-03-2012 07:13 AM
Hi, is it possible to pulse 2 digital output lines on the same channel at the same time using the NI-6009? I'm trying to avoid any time loss while pulsing 2 individual lines independently. Is this possible? If so, how would I configure the DAQmx task?
Thanks.
09-03-2012 05:17 PM
You can simply add all of your channels to a single task - Dev1/port0/line0:3. What programming language are you using?
09-03-2012 10:11 PM - edited 09-03-2012 10:11 PM
Thanks Dennis for your response. I figured it out earlier today and it was as you said. Thanks again.
