Digital I/O
6008 generate signals from timer array connection type to daq assistant
Hi
I'm having difficulty generating a signal using a USB 6008 on labview 2010.
I have a timer array which has varying on/off times and I want to turn the digital port P0.0 of my 6008 on and off.
I keep getting errors telling me the connection type is wrong when I attempt to connect the data port of the daq assistant to the array.
Can someone take a look at my vi and tell me where i'm going wrong.
Much appreciated
(5,240 Views)
my non workiing vi
(5,239 Views)
Hi Andy,
Unfortunately your VI has not been attached to the previous post,
it would be great if you try attaching it once again.
In order to speed up the process could you please copy
errors you are getting during your experiment and paste them into your reply.
Thank you!
All the best,
(5,189 Views)
