DigiMetrix
Speed in mm/s
Hi Iggy,
I am aware of your problem through DigiMetrix and your other post in the forum.
TakeArm is a command that is implemented in RobSlave.pac which should be present on your RC7 controller - otherwise
you would not be able to issue any move command from the LabVIEW library.
Actually you do not have to use or edit RobSlave directly. You might be able to use the function through the UserExtension.vi.
If you want to view the file you can either use your Teaching Pendant or - if you have ORiN installed on your PC - you can
point your windows explorer to "c:\ORiN2\CAO\ProviderLib\DENSO\NetwoRC\Bin\RobSlave.pac".
In RobSlave.pac there are two constants defined:
#define RBS_CMD_TAKEARM         1100
#define RBS_CMD_GIVEARM         1101
As you might guess those relate to the "TakeArm" and "GiveArm" commands (I believe you have access to the programmer's
manual).
Using the UserExtension.vi with either of these constants and "1" or "2" as variables should execute the respective commands.
If this does not work there might still be a chance to extend "UserExtension.pac". But I would give it a try first.
Please let me know if this works or fails.
Alexander
Message 11 of 12
(4,798 Views)
Hi Alexander,
I'm programming exclusively in LV and using the DRL with the 6-axis robot and a separate Denso motor on the 7th axis. I saw the list of command definitions for both robslave.pac and userextension.pac in WINCAPS III. I guess it didn't occur to me to use the DRL's UserExtension.vi for robslave commands, as well. I'll try it out. Thanks for the information.
Iggy
Message 12 of 12
(4,790 Views)
