DigiMetrix
Sampling rate for reading the robot arm position
Hi all:
In this thread a method to monitor the robot arm current position (though may not be properly "real-time")
http://forums.ni.com/t5/ImagingLab-Robotics-Library-for/How-can-I-monitor-the-current-position-amp-s...
I tested the above program and noticed that the sampling rate could be at most around 50 - 100 Hz. I believe the RC-7 controller could monitor the arm position at a much higher sampling rate. I wonder if anyone know how to read the arm position in real time?
(7,367 Views)
I think that the 50-100 Hz rate is a maximum rate for this operation because the controller needs to have some time to calculate its Cartesian current position and to transmit it. Probably you can archive higher rate using Joint representation, but I'm not sure.
Could you please describe your application? What would you like to achieve?
Kind regards,
Nikita.
Software Engineer
Certified LabVIEW Developer
e-mail nikita.prorekhin@digimetrix.com
web www.digimetrix.com
Nikita Prorekhin
CLA
(7,351 Views)
basically the underlying protocol might be able to react in the range of 500 micro seconds.
This depends on the variable accessed by the DENSO robot library. As it seems the library
is using the "@CURRENT_POSITION" variable. The DENSO manual does not say anything
about response time for this variable.
The 500 micro seconds refer to the "@HIGH_CURRENT_POSITION" variable which seems
not to be accessible through the library (I might be wrong, though).
Then it could be a good idea to implement this variable in a future version of the library.
Alexander
(7,334 Views)
