Developer Center Resources
Calling C/C++ DLLs from LabVIEW
by Active Participant Jervin Justin ‎01-18-2010 03:02 PM - edited ‎01-30-2017 09:49 AM
» Calling External Code » Calling C/C++ DLLs
Basics: Call Library Function Node
LabVIEW gives you the ability to call DLLs written in C and C++ using the Call Library Function Node. The Call Library Function Node allows you to specify the DLL you want to use, the function within the DLL you want to call and allows you to configure the inputs and outputs (parameters and return values) of the function.
LabVIEW Help: Configuring the Call Library Function Node
Tutorial: Configuring the Call Library Function Node to call a Simple DLL
Import Shared Library Wizard
The Import Shared Library Wizard can automate a lot of the effort involved in calling C/C++ DLLs by creating wrapper VIs with pre-configured Call Library Function Nodes that you can call from your VIs.
In order to use the wizard to create wrapper VIs, you must have a header file associated with the DLL. The wizard requires this header file in order to properly create the wrapper VIs with the correct inputs and outputs.
Tutorial: Creating Wrapper VIs for C/C++ DLL functions using the Import Shared Library Wizard
Note: While the Import Shared Library Wizard does very well in creating wrapper VIs for functions that use simple data types and stucts of simple data types, it has some limitations especially relating to:
  • Confusion between pointers and Arrays: Since arrays technically are simply pointers to the first element in the array, the Import Shared Library cannot tell them apart.
  • Return Types: Since the Call Library Function Node only allows void, integer and string return types, anything more complex (like structs) must be handled as pointers.
  • Pointers: Pointers to complex types and pointers returned via return value might not be dereferenced (that is, they will be represented as an integer with a value equal to the memory address pointed to).
These caveats are detailed in the following article. The article also includes examples of how to work around them.
Calling C/++ DLLs Containing Simple and Complex Datatypes from LabVIEW
Representing Structs as Clusters
The equivalent for representing structs in LabVIEW is a LabVIEW Cluster. As with structs in C/C++, the ordering of elements in a cluster make a difference, as this is the order in which they are stored in memory. To pass a cluster to a DLL that expects a struct, make sure to order the elements in the cluster in the same order as those in the struct.
For example:
If you create a cluster with the improper order of elements, the elements can be reordered after the fact:
LabVIEW Help: Modifying Cluster Element Order
For examples on calling C/C++ functions that accept or return structs, refer to:
Pointers and References
Several languages like C and C++ employ the concept of pointers, which is basically a variable that holds (points to) the address (in memory) of the data you are interested in. This is especially prevalent in functions that need to return multiple values. In these cases, programmers use a technique called Call By Reference where the parameters are pointers to the values rather than the actual values.
This can be initially challenging in LabVIEW since LabVIEW hides the concept of pointers and memory allocation from the user, as do several modern languages like C# and Java.
There are ways to pass pointers to C/C++ DLLs, as well as to receive and dereference pointers from C/C++ DLLs in LabVIEW. For details refer to:
Passing and Receiving Pointers with C/C++ DLLs from LabVIEW
Dereferencing Pointers from C/C++ DLLs in LabVIEW
Examples
To see how to call a C/C++ DLL from LabVIEW and pass around different types of data (ranging from numerics, string and arrays to pointers and structs/clusters) between LabVIEW and the DLL, refer to:
Child Documents
Comments
Proven Zealot Proven Zealot
Proven Zealot
I find the picture under "Representing Structs as Clusters" rather unfortunately chosen. It would suggest to the normal reader that a structure with an array and/or string pointer in it can be represented by a cluster with an according LabVIEW array or string. Almost nothing is further from the truth than that.
I would rather chose a struct with some skalar elements a an embedded struct and show the according LabVIEW Cluster.
Contributors
