Developer Center Discussions
Error "Project or Library file is corrupt."
after working through the example for "Third-Party Licensing and Activation Toolkit" with "Simple Math" all done well. So I tested it with one of our own toolkits. It seemed to work fine but after trying to open the created licensed lvlib I got the message "Project or Library file is corrupt.".
Any ideas?
Peter
(5,693 Views)
Got the problem solved. After comparing the lvlib files (licensed & unlicensed) I found that the containing .mnu lines where different. I removed them from library and could start the licensed lvlib without problems.
(5,091 Views)
Thank you for the update.  Were the .mnu lines modified during the license binding or were they incorrect in the source library file as well?
-R
(5,091 Views)
This was the difference between the lvlibs, original to the right, licensed to the left:
(5,091 Views)
