Join the Sev Kamenskihs, Embedded Systems Applications Engineer, to learn about using and installing NI Linux Real-Time with LabVIEW.
Examine useful packages you can install in your NI Linux Real-Time distribution and their interactions with LabVIEW. Examples include enhancing user mode security through the use of IP tables and file encryption, accessing an NFS file system for distributed applications, and installing GCC, Python, and node.js to compile and reuse code. Build your knowledge and toolbox so you can make the most of the existing open source IP available to run on your NI Linux Real-Time target.
Register Now!
