Congratulations to the winners and finalists of the LabVIEW Tools Network Awards for 2016!
A product that leverages domain expertise to tackle a particular application space. Examples of applicaton spaces include condition monitoring, data acquisition, wireless test, and more.
GTT LTE RBS Toolkit by Gefle Testteknik
A product that enables the NI platform to connect with, communicate with or control third-party systems. Third-party systems include hardware, software, protocols, languages, and services.
BACnet Protocol for LabVIEW Toolkit by Ovak Technologies
A product that enables developers on the NI platform to enhance their efficiency and productivity through reusable code, editor extensions, or software management tools.
UI Controls Suites by RAFA Solutions
A free product that gives back to the NI community, empowering its members to advance their knowledge and expertise.
Delacor Queued Message Handler (DQMH) by Delacor
Algorithms after Dijkstra and Kruskal for Big Data by Ovak Technologies | Shortest-Path and Minimum-Spanning Tree-Finding Algorithms | https://www.ni.com/en-us/shop/product/algorithms-after-dijkstra-and-kruskal-for-big-data-and-iot-too... |
LossLess Coding Library by OLYMP Engineering | Lossless Signal Compression and Decompression | https://www.ni.com/en-us/shop/product/lossless-data-compression.html |
Wezarp Lite | Control LabVIEW and LabWindows/CVI™ Applications Remotely | |
Metrology Lab by RAFA Solutions | Academic Lab Software for NI ELVIS | https://www.ni.com/en-us/shop/product/metrology-laboratory-software.html |
Finance OHLC Plot by Austin Consultants | An Efficient Tool to Visualize Financial Data | |
BACnet/IP Protocol by Ovak Technologies | Communicate Between BACnet Devices and NI Hardware | https://www.ni.com/en-us/shop/product/bacnet-ip-protocol.html |
git4G by DATA AHEAD GmbH | Integrate Git Control Management Into a LabVIEW Environment | https://www.ni.com/en-us/shop/product/git4g.html |
Reflective Ethernet Custom Device by Dvel AB | Direct Target-to-Target Reflective Ethernet Communication | |
VI Suggester by Austin Consultants | Doubles the Speed of Programming by Proposing the Next V | |
LogBook Toolkit by Step Automation & Test | Trap, Store, and Display All Your Application Events | https://www.ni.com/en-us/shop/product/logbook-toolkit.html |
LIA-SFP (Lock-In Amplifier Soft Front Panel) by Ngene | Convert FPGA-Based DAQ Into Multichannel Lock-In Amplifier | https://www.ni.com/en-us/shop/product/lock-in-amplifier-soft-front-panel.html |
Python Integration Toolkit by Enthought | Seamlessly Extend Capabilities With the Power of Python | |
Waveform Compression by ST Solutions | Waveform Compression | https://www.ni.com/en-us/shop/product/waveform-compression-toolkit.html |
Colorful UI Controls Palette by Bitlis-MEN | Colorful UI Controls Palette for LabVIEW | https://www.ni.com/en-us/shop/product/colorful-ui-controls-palette.html |
Ultra Light UI Controls Palette by Bitlis-MEN | Ultra Light UI Controls Palette for LabVIEW | https://www.ni.com/en-us/shop/product/ui-controls-palette.html |
eHS – Power Electronics Simulation Tool for cRIO-9068 by OPAL-RT TECHNOLOGIES | Simulation on FPGA Made Easy | |
eHS – Power Electronics Simulation Tool for cRIO-9039 by OPAL-RT TECHNOLOGIES | Simulation on FPGA Made Easy | |
SVG Reader for LabVIEW by Ngene | Read SVG Vector Graphics in LabVIEW | https://www.ni.com/en-us/shop/product/svg-reader-for-labview.html |
ClampOn CAN Monitor by ClampOn AS | Configure, Test, and Monitor Your CAN Network and Devices | https://www.ni.com/en/support/downloads/tools-network/download.clampon-can-monitor.html |
DataGrid for LabVIEW by Mike King | An Easy-to-Use Data Grid Table Solution for LabVIEW | https://www.ni.com/en/support/downloads/tools-network/download.datagrid-for-labview.html |
NIVision OpenCV Utilities | Quickly Integrate Open Source Vision Algorithms Into LabVIEW | https://www.ni.com/en/support/downloads/tools-network/download.vision-opencv-utilities.html |
Phase Coherent Acquisition and Generation (PCAG) Toolkit by INSol | Multichannel Phase-Coherent Acquisition and Generation Kit | https://www.ni.com/en/support/downloads/tools-network/download.phase-coherent-acquisition-and-genera... |
Claudie_XLSX by ATEsystem | Read and Write Microsoft Excel Files in LabVIEW | https://www.ni.com/en/support/downloads/tools-network/download.compact-library-and-universal-data-im... |
ChipScopePro Break-Out-Box by B&A Engineering | Debug FPGA Code in Real Time | https://www.ni.com/en/support/downloads/tools-network/download.xilinx-chipscope-pro-debugging-break-... |
Physics Lab Assistant by Doug Harper | Data Acquisition and Analysis for Physics Laboratories | https://www.ni.com/en/support/downloads/tools-network/download.physics-laboratory-assistant.html |
Virtual Physics by Doug Harper | Numerically Integrate Differential Equations of Motion | https://www.ni.com/en/support/downloads/tools-network/download.virtual-physics.html |
SoftMotion Drive Interface Plugin-In for ASD-A2-E by Delta Product Corp | SDI Plug-In for Delta ASDA Servo Drives | https://www.ni.com/en/support/downloads/tools-network/download.softmotion-drive-interface-plug-in-fo... |
Distributed Control and Automation Framework by NI Systems Engineering | LabVIEW Application Framework for Embedded Control Systems | https://www.ni.com/en/support/downloads/tools-network/download.distributed-control-and-automation-fr... |
GDrive for LabVIEW by National Instruments | Access Your Google Drive Items from LabVIEW | https://www.ni.com/en/support/downloads/tools-network/download.gdrive-for-labview.html |
pdfLaTeX for LabVIEW by Kinga Kasiak | Export Data From LabVIEW to TeX File and Compile to PDF | https://www.ni.com/en/support/downloads/tools-network/download.pdflatex-for-labview.html |
AVP254 - Automatic Verification Platform for Safety-Critical FPGA by Barco Silex | The Smart Solution for FPGA Physical Testing | https://www.ni.com/en/support/downloads/tools-network/download.avp254.html |
