Delacor Toolkits Discussions
Reply
DQMH Main in the UI Execution System
Highlighted
I rarely change the "Preffered Execution System" of a VI but I just got an error in my main that may require it.  I want to see peoples thoughts on that.
On my main I am adding an ActiveX control to load a PDF.  When I load the PDF I get error: "Error 3006 occurred at Automation Interface can only be used in the User Interface Execution System."
So... I can make the main in the UI, but I am not sure that is the best method.  I guess I could make a subVI and use a subpanel.
Thoughts?
(509 Views)
Re: DQMH Main in the UI Execution System
All bets are off with ActiveX and .NET. I had a similar situation a while back where the main VI of my (non-DQMH) app just wouldn't work at all unless I ran the VI in the UI thread. It was doing a bunch of .NET stuff.
Darren Nattinger, CLA
LabVIEW Artisan and Nugget Penman
(506 Views)
Is there any specific "danger" to running the DQMH in the UI?  It has been awhile since I dove into the pros and cons of execution systems, but I do remember UI being one I didn't generally play with, thought I thought property nodes where in the UI thread....
(504 Views)
Accepted by topic author Evan
03-16-2017 10:19 AM
I don't think there's any danger in running the DQMH main VI in the UI thread.
(502 Views)
