Data Acquisition Idea Exchange
About Data Acquisition Idea Exchange
Have an idea for new DAQ hardware or DAQ software features?
  1. Browse by label or search in the Data Acquisition Idea Exchange to see if your idea has previously been submitted. If your idea exists be sure to vote for the idea by giving it kudos to indicate your approval!
  2. If your idea has not been submitted click Post New Idea to submit a product idea. Be sure to submit a separate post for each idea.
  5. Give kudos to other ideas that you would like to see implemented!
cRIO Analog In/Out Combination Modules
As someone who migrated entire product lines from PLCs to cFieldPoint platforms, and now is in the process of migrating further into cRIO platforms, I am finding some cRIO module selection limitations.  One big gap I see in the selection is with analog in/out modules.  A set of 2-in / 2-out analog modules would be very welcome, offering standardized +/- 10V or 0-20mA ranges.  There are a many times in our products that we need to process just a single analog signal, which now with cRIO requires 2 slots be used, with many unused inputs and outputs (which just feels like a waste of money and space).
1 Comment
Member abh
i am also facing the same problem with cRIO, as in my knowledge you have to create it , configure it and then you can use it in your application
