Data Acquisition Idea Exchange
About Data Acquisition Idea Exchange
Have an idea for new DAQ hardware or DAQ software features?
  1. Browse by label or search in the Data Acquisition Idea Exchange to see if your idea has previously been submitted. If your idea exists be sure to vote for the idea by giving it kudos to indicate your approval!
  2. If your idea has not been submitted click Post New Idea to submit a product idea. Be sure to submit a separate post for each idea.
  5. Give kudos to other ideas that you would like to see implemented!
Top Kudoed Authors
Terminal Block layouts
NI Terminal block layout should be designed so that wiring can be done straight from terminal to wire trunking.
For example TBX-68 has 68 wire terminals aligned to inside of the terminal block. This causes that each wire should make tight curve to wire trunking. Another problem with TBX-68 is that wires are heavily overlapped because of the terminal alignment.
Also the cables from terminal block to DAQ device should be aligned to go directly to wire trunking (not straight up).
1 Comment
N/A
In addition can you please use off the shelf standard SCSI connectors?
The connector on the CB68LPR has an upside down shell. This is not immediately obvious and doesn't offer any advantages to the user.
I have stuffed up two custom PCBA layouts wtih SCSI connector due to this problem. First time I didn't have a CB68LPR as a reference, so 2nd time I was wary of the issue and carefully copied the pin out on the CB68LPR not relaising the shell of the connector was upside down.
And the 777600-01 connector offered on the website is a standard SCSI connector.
