Data Acquisition Idea Exchange
About Data Acquisition Idea Exchange
Have an idea for new DAQ hardware or DAQ software features?
  1. Browse by label or search in the Data Acquisition Idea Exchange to see if your idea has previously been submitted. If your idea exists be sure to vote for the idea by giving it kudos to indicate your approval!
  2. If your idea has not been submitted click Post New Idea to submit a product idea. Be sure to submit a separate post for each idea.
  5. Give kudos to other ideas that you would like to see implemented!
Show "Advanced" DAQmx Terminals by Default
By default, DAQmx terminal constants/controls only show a subset of what is really available.  To see everything, you have to right-click the terminal and select "I/O Name Filtering", then check "Include Advanced Terminals":
I guess this is intended to prevent new users from being overwhelmed.  However, what is really does is create a hurdle that prevents them from configuring their device in a more "advanced" manner since they have no idea that the name filtering box exists.
I am putting "advanced" in quotes because I find the distinction very much arbitrary.
As a more experienced DAQmx user, I change the I/O name filtering literally every time I put down a terminal without thinking about it (who can keep track of which subset of DAQmx applications are considered "advanced").  The worst part about this is trying to explain how to do something to newer users and having to tell them to change the I/O name filtering every single time (or if you don't, you'll almost certainly get a response back like this).
Why not make the so-called "advanced" terminals show in the drop-down list by default?
2 Comments
Member EngYasir
Hi
I have NI USB-6251 and I have to use maximum sampling rate 1250 Khz how i could put anti-aliasing filters? help please
also I have NI 9234 to receive a signal from the 4-Channel with sampling rate 50 khz for each channel should I put anti-aliasing filters in this case or not?
thanks
Knight of NI Knight of NI
Knight of NI
Your question belongs in the LabVIEW forum or Multifunction DAQ.
It does not belong in the Idea Exchange which is about new ideas to improve LabVIEW.
