It should be read programattically what parameters a DAQ Card supports!!
Announcements
The NI Idea Exchange is a product feedback forum where NI R&D and users work together to submit ideas, collaborate on their development, and vote for the ones they like best. View all of the NI Idea Exchanges to post an idea or add your opinion on an existing one today!
Any series card should have a feature listing different parameters like voltage, temperature etc it supports(May be a property node should be used). so that user can configure the required parameter among the supported.
Ex: SCXI -1520 module can be configured as Strain, Pressure or voltage but this information will be known only by seeing its manual or when a task is created in MAX. But in LabVIEW Software i cant get this information directly. Because it allows me to configure 1520 as temperature also and we will come to known that 1520 module doesn't support for temperature parameters only when once tried to acquire.
So what you people think about you.Share your ideas on this please.
You must be a registered user to add a comment here. If you've already registered, please log in. If you haven't registered yet, please register and log in.
Have an idea for new DAQ hardware or DAQ software features?
Browse by label or search in the Data Acquisition Idea Exchange to see if your idea has previously been submitted. If your idea exists be sure to vote for the idea by giving it kudos to indicate your approval!
If your idea has not been submitted click Post New Idea to submit a product idea. Be sure to submit a separate post for each idea.
Watch as the community gives your idea kudos and adds their input.
As NI R&D considers the idea, they will change the idea status.
Give kudos to other ideas that you would like to see implemented!
