Improve the memory management when setting standard waveforms on AWGenerators
Announcements
The NI Idea Exchange is a product feedback forum where NI R&D and users work together to submit ideas, collaborate on their development, and vote for the ones they like best. View all of the NI Idea Exchanges to post an idea or add your opinion on an existing one today!
byHenrik_Volkers09-12-201107:15 AM - edited 09-12-201107:17 AM
If you want to create low frequencies with AWGs (5422) you need to increase the buffer manually, OK would be nice to have an option that the driver can do it.... however
currently the driver (seems to) try to fill the buffer at once, allocating huge amounts of memory only to write a standard function.
Ever tried 50mHz@5MS/s
Please improve the memory management of the FGEN driver by writing smaller blocks...
You must be a registered user to add a comment here. If you've already registered, please log in. If you haven't registered yet, please register and log in.
Have an idea for new DAQ hardware or DAQ software features?
Browse by label or search in the Data Acquisition Idea Exchange to see if your idea has previously been submitted. If your idea exists be sure to vote for the idea by giving it kudos to indicate your approval!
If your idea has not been submitted click Post New Idea to submit a product idea. Be sure to submit a separate post for each idea.
Watch as the community gives your idea kudos and adds their input.
As NI R&D considers the idea, they will change the idea status.
Give kudos to other ideas that you would like to see implemented!
