Data Acquisition Idea Exchange
About Data Acquisition Idea Exchange
Have an idea for new DAQ hardware or DAQ software features?
  1. Browse by label or search in the Data Acquisition Idea Exchange to see if your idea has previously been submitted. If your idea exists be sure to vote for the idea by giving it kudos to indicate your approval!
  2. If your idea has not been submitted click Post New Idea to submit a product idea. Be sure to submit a separate post for each idea.
  5. Give kudos to other ideas that you would like to see implemented!
Top Kudoed Authors
User Kudos Count
1
1
Improve DAQmx Flatten Channel to String.vi
  1. DAQmx Flatten Channel to String.vi still uses an unbundle function to wire the error status to the case structure.
  2. The Call Library Function Node should be wired to the error cluster.
6 Comments
G-Money
N/A
I agree that this VI should be updated to incorporate proper modern LabVIEW programming techniques. I am going to move this Idea over to the DAQ Idea Exchange so that the R&D team that works with DAQmx will see this and hopefully incorporate this into the next iteration.
JB
N/A
Thank you G-Money.
Seth_B.
N/A
Just to let you know, I've shown this post to the group that owns this function and they have a Corrective Action Request filed to make these updates.
JB
N/A
Very well ! Thank you very much.
Seth_B.
N/A
Status changed to: In Development
JB
N/A
Nice ! There are probably some other VIs that need this kind of update...
