Data Acquisition Idea Exchange
Kumar_B
DAQmx Physical channel-I/O Name filtering based on module product type/device name
Status: New
I am using DAQmx Physical channel controls in user Interface to select the particular DAQ modules.I would like to display only the particular type (AI,DI,AO,DO.....) of modules which is connected in the system.For example i need to display only, DO-NI-9477 cDAQ modules in the physical channel not the other DIO models like NI 9403...IO name filtering option not useful to filter the other models which is same type.
That should be great if NI provides the option for filtering the modules name based on their  product type or user configurable naming (for example, if cDAQ1 device renamed as "DEV1" means user can enter filter the device based on the string "DEV").
1 Comment
kevin.brown
I'm in this situation now where I need multiple devices, but not all.  It would be nice simply to select multiple devices from the dropdown menu.
