NI Home
Cart Cart | Help
You are here:
Announcements
The NI Idea Exchange is a product feedback forum where NI R&D and users work together to submit ideas, collaborate on their development, and vote for the ones they like best. View all of the NI Idea Exchanges to post an idea or add your opinion on an existing one today!
Frank-L
Allow test panels to provide voltage excitation for bridge/strain modules
Status: Implemented
by Member Frank-L on ‎03-07-2011 03:25 PM
Currently, DSA devices that use voltage excitation have no method to provide that excitation to a particular device within test panels. The only method to do this would be to create a task in Measurement and Automation Explorer which takes much more time that doing a simple test panels test. This should be a fairly simple addition to the test panels user interface. One could simply have a box to check if they require excitation, and a control to determine the voltage level to provide to the DUT. They currently have this for IEPE devices, and it makes sense that voltage excitation should be the same.
Status: Implemented
Comments
by Active Participant Brad_K ‎04-04-2011 09:37 PM - edited ‎04-04-2011 09:37 PM
Hi Frank,
Have you seen the new multi-measurement test panel that was added for SC Express? On the PXIe-4330 and PXIe-4331 bridge/strain modules, the new test panel supports configuring the bridge type and excitation. On the PXIe-4353 thermocouple module, it supports switching between voltage and thermocouple measurements without creating a task in the DAQ Assistant.
In NI-DAQmx 9.3, CompactDAQ analog input should be getting a test panel upgrade.
Brad
by Trusted Enthusiast on ‎04-05-2011 12:32 PM
Status changed to: In Development
Status changed to: Implemented
About Data Acquisition Idea Exchange
Have an idea for new DAQ hardware or DAQ software features?
  1. Browse by label or search in the Data Acquisition Idea Exchange to see if your idea has previously been submitted. If your idea exists be sure to vote for the idea by giving it kudos to indicate your approval!
  2. If your idea has not been submitted click Post New Idea to submit a product idea. Be sure to submit a separate post for each idea.
  5. Give kudos to other ideas that you would like to see implemented!
Idea Statuses
Top Kudoed Authors
User Kudos Count
4
3
2
2
2
