Data Acquisition Idea Exchange
About Data Acquisition Idea Exchange
Have an idea for new DAQ hardware or DAQ software features?
  1. Browse by label or search in the Data Acquisition Idea Exchange to see if your idea has previously been submitted. If your idea exists be sure to vote for the idea by giving it kudos to indicate your approval!
  2. If your idea has not been submitted click Post New Idea to submit a product idea. Be sure to submit a separate post for each idea.
  5. Give kudos to other ideas that you would like to see implemented!
Allow Multiple Test Panels Simultaneously Through MAX
I often use one DAQ device to test the basic functionality of another device and like to be able to quickly do this through test panels.  Unfortunately, MAX does not allow the user to open more than a single test panel at once.  The current workaround for this is to launch the test panels outside of MAX (see this KB).
It would be nice to have the same functionality when opening test panels in MAX.  Specifically, I would like to be able to do the following with a Test Panel open:
1.  Be able to navigate through MAX to do things like check device pinouts, calibration date, etc.
2.  Be able to move and/or resize the original MAX Window (it always seems to be blocking other applications that I want to view alongside the Test Panel)
3.  Open a test panel for a second (or third...) device.
It is nice that there is a workaround in place already but I think it would be nice if MAX had this behavior to begin with.
John Passiak
1 Comment
Another workaround for issues #1 and #3 is to open a second instance of MAX, but this doesn't help with issue #2.
Brad Keryan
NI R&D
