Currently with a multislot chassis, the system will operate at the requested sampling rate even if that rate is above the maximum supported by the module. In this case, the chassis will replicate the additional required data points from the previous sample, and will not return an error in NI MAX. With a single slot chassis, this is not an option. However, it would be helpful if this feature was also supported with the single slot chassis so that data could be replicated at a higher sample rate without returning an error message.
