Data Acquisition Idea Exchange
About Data Acquisition Idea Exchange
Have an idea for new DAQ hardware or DAQ software features?
  1. Browse by label or search in the Data Acquisition Idea Exchange to see if your idea has previously been submitted. If your idea exists be sure to vote for the idea by giving it kudos to indicate your approval!
  2. If your idea has not been submitted click Post New Idea to submit a product idea. Be sure to submit a separate post for each idea.
  5. Give kudos to other ideas that you would like to see implemented!
Add support for multidevice tasks on M Series
Is there any technical reason why this cannot be added to DAQmx?  M series boards still have features that cannot be found on X or S series such as analog current input.
Ideally, it would be best to be able to have multidevice tasks for both M and X at the same time.
5 Comments
Knight of NI
Exactly what are you asking for? You can have as many different analog input/outputs (i.e. AI Voltage and AI Current) as you want in a single task. You cannot have separate tasks for the same resource since there is only a single clock for each resource. This has been endlessy discussed.
Multi-device is the key word here.  You cannot arbitrarily create an AI task with channels from multiple devices unless they meet certain criterion which is that they all must be from the same device type (X,S or DSA but not currently M series)
Trusted Enthusiast
The feature sachsm is asking for is currently available on some other NI products.  It allows for users to synchronize multiple devices by simply configuring them as a single task (they must be either in the same PXI chassis or configured on the same RTSI cable--the sharing of clocks and triggers is then configured for you under-the-hood).  However, the feature is not currently available for M Series.
John Passiak
Just to be restating my original post, the feature I am asking for is specifically multidevice AI tasks for M series cards and then possibly the ability to mix device types into the same task as well.
Why was that so hard to understand?
Trusted Enthusiast
Makes sense to me--there isn't really a technical reason why this wouldn't be possible (depending on what other types of devices you intend to synch to).  However, the underlying M Series code isn't really set up for this so there would be a good deal of software effort required to implement the feature.  This priority of this feature would have to be evaluated against other new features that are being developed.
John Passiak
