NI Home
Cart Cart | Help
You are here:
Announcements
The NI Idea Exchange is a product feedback forum where NI R&D and users work together to submit ideas, collaborate on their development, and vote for the ones they like best. View all of the NI Idea Exchanges to post an idea or add your opinion on an existing one today!
BasvanDijke
Add documentation about different channel properties
Status: New
by Active Participant BasvanDijke on ‎01-18-2011 04:54 AM
Currently it is hard to find out whether a property can be set for a specific channel, or only per module. An example is the Strain Gauge Excitation property, which can only be set per module. Other properties can be different per channel.
Idea: Add a device specific comment in for example Max, about the different properties.  For example:
Comments
by Active Participant Brad_K on ‎02-03-2011 04:02 PM
I like the idea of documenting the specifics of DAQmx property behavior better. Here are some additional things to consider:
  • A given property may be per-device on some device types and per-channel on other device types. For example, the SCXI-1520 supports setting different excitation values on each channel, but the SCXI-1122 requires you to set the same excitation value on all channels. How would you recommend handling this case?
  • The DAQ Assistant supports setting a property on multiple channels at the same time, and these channels may be on different devices. What would be displayed when you shift-select channels from both an SCXI-1520 and an SCXI-1122?
by Active Participant BasvanDijke on ‎04-08-2011 07:20 AM
There are two options.
You start from the properties and start documenting each device.
You start from the device and start documenting each property.
Isn't it an idea to have device specific info available in the specs? Then you can point to the specs.
About Data Acquisition Idea Exchange
Have an idea for new DAQ hardware or DAQ software features?
  1. Browse by label or search in the Data Acquisition Idea Exchange to see if your idea has previously been submitted. If your idea exists be sure to vote for the idea by giving it kudos to indicate your approval!
  2. If your idea has not been submitted click Post New Idea to submit a product idea. Be sure to submit a separate post for each idea.
  5. Give kudos to other ideas that you would like to see implemented!
Idea Statuses
Top Kudoed Authors
