I know it is possible to listen for multiple DI lines when performing a Change Detection (with a pxi 6511, for example), however it appears to not be a feature to know which channel was the cause of the event trigger without building your own comparison logic around the DIO reads.
I would like to see an additional property, either under 'Timing', or under 'Channel' that would allow me to ask, for the specific channel / line in the task that caused the change-event instance rather than having to search for it manually in a 1D boolean array.
