Data Acquisition Idea Exchange
About Data Acquisition Idea Exchange
Have an idea for new DAQ hardware or DAQ software features?
  1. Browse by label or search in the Data Acquisition Idea Exchange to see if your idea has previously been submitted. If your idea exists be sure to vote for the idea by giving it kudos to indicate your approval!
  2. If your idea has not been submitted click Post New Idea to submit a product idea. Be sure to submit a separate post for each idea.
  5. Give kudos to other ideas that you would like to see implemented!
Top Kudoed Authors
User Kudos Count
1
Add 64bit Linux support to DAQmx
It would be great to develop software on 64bit Linux sytem using DAQmx.
Since we`re developing software for 64bit Linux this is a must for us - this means a 64bit Kernelmodule as well as 64bit libraries.
11 Comments
Same true for our company...
Same here
same for me
Knight of NI
If you want this, then be sure to give it Kudos.  Otherwise R&D won't really see it.
The discussions from the Advanced User Track is not over. Join in the conversation: 2016 Advanced Users Track
This significance
萤火虫
ibm0815 已写:
Same here
Knight of NI
Again, just comments saying that you want this will not help your cause of getting this moved up the chain.  NI looks at the Kudo count when they go through the Idea Exchange.  So if you really want this implemented, you HAVE to give it kudos.
Many Industries such as Energy are demanding Linux Desktop 64 Bits. It is worth spending R&D effort on it.
