06-06-2006 02:58 PM
06-07-2006 10:47 AM
Hello Rich,
As best I can tell, the default CSV file reader that ships with DIAdem is stumbling over the simple linefeeds at the end of your file's lines (CRLF is more standard). Everything else looks just like it should expect it, though you would get an empty channel at the end. I'll forward that on to R&D for fixing.
In the meantime, try this DataPlugin I created for you. Let me know if this somehow also gives you trouble.
Cheers,
Brad Turpin
DIAdem Product Support Engineer
06-07-2006 05:01 PM
06-12-2006 09:18 AM
06-12-2006 09:20 AM
06-13-2006 01:46 PM
Rich,
The FTP server is cleaned every few days, and only internal NI employees are able to download information from the /incoming folder.
With the three data files we have now, and the data plugin posted above, we have been unable to reproduce the incorrect time values you have been seeing. Are you seeing this behavior with any of these three files, or with other files?
Since we have been unable to reproduce the behavior, we don't know exactly what's going on. So if you could send along a screenshot of the behavior that you are seeing, we will be able to assist you better. If you are seeing this behavior with a file other than the three we have, if you could also send along that file, it would help a lot.
Josh W. | National Instruments | Applications Engineering
06-13-2006 02:25 PM
06-13-2006 03:01 PM
06-13-2006 04:09 PM
