I have used demo 2015 32 bit Diadem before purcahsing software for 2015 Diadem.
I have used time requency order analysis VBS script for finding RPM from tach signal on Bentley probes.
It worked well but when I bought Diadem software and try to convert RPM from tach signal using this script, I get the following error in the VBS script.
See the attachment.
Let me know what is the issue in fixing this error in VBS script.
„naviwfimport“ i spart of the compatibility settings of the DIAdem 32 bit versions. If you installed the 64 bit version of DIAdem 2015 all compatibility settings are not supported anymore.
I checked the possible options of „naviwfimport“ with DIAdem 2015 32 bit and it worked fine (and I have installed the 32 bit version and the 64 bit version in parallel).
