DIAdem
there is no data loaded in DIAdem message
I am getting this message when I try to load a .LVM file into DIAdem.
"There is no data loaded in Diadem"
"The report wizard appears with the dialog for data selection"
This only happens on the last few of my files.  Other files will open.  What does this message mean?
(2,830 Views)
Hi MEY,
It sounds like it means that for some LVM files DIAdem fails to load their values.  Do those last few files fail to load if you drag them one at a time from the NAVIGATOR into the Data Portal?  What version of DIAdem are you using?  LVM files are known to often contain inconsistencies in the header that confuse DIAdem, if it is just a few LVM files that give you trouble, why don't you send them over for us to look at.
Brad Turpin
DIAdem Product Support Engineer
(2,804 Views)
