06-27-2006 12:11 PM
BSc. MSc. Felix Beltran MIEE
Control & Instrumentation Engineer
CONVERTEAM Ltd.
formerly ALSTOM Power Conversion
Process Industries Department
Rugby CV21 1BU
United Kingdom
07-03-2006 10:02 AM
07-03-2006 10:43 AM
07-04-2006 04:15 AM
07-04-2006 04:22 AM
Felix,
Sorry I posted the wrong version. Please try teh one below
Andreas
07-04-2006 08:21 AM
07-04-2006 08:31 AM
Felix,
Most of the DIAdem commands are not available in the DataPlugin environment. The DataPlugin are running several levels below the DIAdem script level. The best way not to mix up the two levels is to specifically to the DataPlugin documentation only when writing the plugin. We tried to provide all the functionality you may need when dealing with the file in the DataPlugin API. If you find that something is missing, please le ust know what you are trying to do and we wil try to provide a solution or review the request when working on the next release. As you can see from the ni.com/dataplugins page, we were able to develop quite a diversity of different plugin with the current functionality.
Just as an FYI : While the API is kind of limited, we were able to keep the whole DataPlugin environment pretty lightweight which is a major advantage when the DataPlugins are used in the DataFinder to index your files.
Andreas
