05-10-2006 09:36 AM
05-10-2006 09:38 AM
05-10-2006 04:28 PM
Hello Julia,
please see "ChnConcat". This function concatenates two channels and should do what you are looking for. Its definitely much faster than copying all teh channels value by value.
Andreas
05-11-2006 01:48 PM
Hi Julia,
This is a common use-case. Check out the following Example Program on the ni web:
Make sure you choose the "_91_" version, which is more robust, more full-featured, and faster (but will only run on DIAdem 9.1 or later). If you are loading TDM files, just use the "Binary_Files" version and type in "TDM" for the DataPlugin name in the VBScript.
Ask if you have further questions,
Brad Turpin
DIAdem Product Support Engineer
National Intruments
