Actually, DIAdem 9.1 is a very stable version. If you are continuously
experiencing crashes this might be due to some problems with your
computer hardware or configuration.
Is your PC matching the recommended system requirements as found in the
helpfile? What OS are you using, did you install the most recent
servicepacks?
Do you have similar problems with other software on this computer as
well? Unexpected system crashes often occure because of corrupt
RAM chips. DIAdem is using a lot of memory - so maybe you are accessing
regions that other programs dont use and - for that reason - see
the crashes only in DIAdem.
You are writing that the processing takes 3 times longer than expected.
How do you compare? Have you been using elder versions of DIAdem which
were faster, or are you comparing with the processing speed of another
computer?
- There are some things I would do to try to improve the performance.
- Check that you have at least 256MB RAM
- Check that you are using Windows 2000 with servicepack 4 or XP with servicepack 1 at least
- Reinstall DIAdem, use the version 9.1 SP2 instead of the installer you have been using. You can download this installer here.
Add servicepack 2b afterwards. The latter is a selfextracting zipfile
which has to be unpacked in the DIAdem directory while the first is a
complete DIAdem installer.
- Replace the RAM modules of your PC.
You are welcome to post again if you dont get any further. In this case
please give some more information about the system such as CPU, OS,..
and the crashes. When do they occure? Is it a specific function or
module you are using when DIAdem crashes. What does the error messages
tell you about the module in which the exeptions occure?
Regards
Ingo Schumacher
Systems Engineering Manager CEERNational Instruments Germany
