04-02-2007 08:51 AM
04-02-2007 10:27 AM
04-03-2007 04:00 AM
Thank you you very much!!!
i have tried to complete the plugin for my file but i'm not made for programming...;(
i put my original data file in the attachment...maybe you can look over it...
THANK you!!!!
BR
Andreas
04-03-2007 04:42 AM
Andreas,
Looking at the plugin I would like to clarify a few things first :
There are two sections in the file "[Test Points]" and "[Test Data]". Should the plugin read the data from both sections ? Are there potentially more sections of this type ?
There are other sections before [Test Points] and [Test Data]. Should the plugin read the values from this section as properties (Eigenschaften) ?
Andreas
04-03-2007 04:42 AM
Andreas,
Andreas
04-03-2007 04:50 AM
hy,
the first (i think) 27 rows are just setup-data...it is not important that i know this bc i write the original filename in my report so i can look if i need it...so you can ignore them
after these rows there are first [test1] and [testresult1] and after that the same data just instead oft [test1]=X1 and [testresult1]=Y1... i need just the test and testresult data in 2 channels...but how many test and testresults i have is different...but there is a value for that...
is this possible??
thanks in advance
BR
andreas
04-03-2007 05:17 AM
Andreas,
OK, this one read the measurement data only. Extending it to read the parameters in the file header would be straightforward. Let me know if you have questions.
Andreas
04-03-2007 07:15 AM
hy,
its working awsome!!!
THANK YOU!!!
if i have more questions i will post them...thank you!!!
BR
Andreas
