10-11-2014 06:17 AM
Hi forum,
I am trying to read the IRIG106 (.CH10) using dataplugin IRIG106 dataplugin http://www.ni.com/example/31585/en/
Can any one help me how to read a file using this dataplugin either in LabVIEW or Diadem.
I have tried using this dataplugin to read IRIG106 (file Extn .ch10) in LabVIEW but LV is getting crashed without any reason !
thanx in advance.
Solved! Go to Solution.
10-13-2014 04:31 AM
Hi A_LI,
Let's try first with DIAdem, which is easier, then we can make it work in LabVIEW. Can you send me a sample IRIG data file for me to test with? Or you could email it to me at brad.turpin@ni.com.
Brad Turpin
DIAdem Product Support Engineer
10-15-2014 12:16 AM
hi Brad,
thank you for your quick reply i have mailed you the sample file and i will would wait for your response
10-28-2014 08:46 PM
Hi All,
The changes made to the IRIG_106 DataPlugin to read these new data files were posted to the www.ni.com/dataplugins website today.
Brad Turpin
11-29-2017 02:34 AM
Any way you can port this IRIG-106 Chapter 10 format to LabVIEW?
11-29-2017 09:36 AM
Hi Sean,
The Storage VIs (off the File I/O palette) enable you to use any DataPlugin in LabVIEW.
Brad Turpin
