09-07-2015 05:26 AM
Hi all,
i have a text file with a line of more than 1000, which contains information about the user name and password etc. i want to write a script to parse my text file into a Data Base using DIAdem. i don't have any work experience in VBS or DIAdem. can any one please guide me on this.
Thanks in advance for your reply.
Shruthi,
09-07-2015 03:47 PM
Hi Shruthi,
Actually, DIAdem doesn't give you any functionality for this task that you don't already have with a VBScript running in the Windows Scripting Host. You can use the built-in FileSystemObject to open the text file, the Split() command to parse out the values left to right, and the ADO object to open a connection to the data base and insert the new records.
Brad Turpin
DIAdem Product Support Engineer
