10-26-2006 10:47 AM
I’m using DIAdem 10.0 and LabView 8.2. Trying to simulate a multi channel DAQ system, saving data as tdms. When using DIAdem Data Portal to load tdms data, the data come is as 1 Group (multi channels in one group) but when I use LabView and DIAdem to open / read / create report the data is loaded into DIAdem as multiple groups. One can use the LabView examples to reproduce this issue. Can someone help with some code that will open / read / create reports that keeps multi channel data as a single group? This will make it much easier to create a tdr template for multi page reports.
thanks
10-26-2006 04:04 PM
I have attached images of the DIAdem Data Portal. One image is data loaded using DIAdem_Report Express VI, the other image the same data was manually loaded into the DIAdem Data Portal. Any Help?
thanks!
10-27-2006 10:47 AM
10-27-2006 02:53 PM
10-30-2006 06:10 PM
